Languages
Alphacool NexXxoS HP Pro Sockel 775
  • Product No.:11700
  • Shipping time: 3-4 Days
  • Print product data sheet:
  • Item may vary slightly from product image.
  • Lieferstatus: Lager voll
from 24,95 EUR
incl. 19 % Tax
excl.
The NexXxos HP Pro is a copper cooler with parallel channels in a PCF(c) construction. Additionally, the channels are drilled in 90° angles - thus the surface area is enourmously increased for heat transfer.
The copper surface is glass-beaded in order to increase the cooling surface once again.
The cooler has a patent-applied nozzle unit with return canals for quicker transport of warm water.
The flow resistance is reduced by 30%, which is a very good condition for systems with G1/4" connections and 10/8 mm tubing.
The surface of the cooler is even and polished.
Technical Data:
Dimensions: (L x W x H): 99 x 62 x 13mm
Gewicht: approx. 0,130 kg
Structure: Copper base and Plexiglas fastening bracket
Nozzles: 17
Customers who bought this product bought also the following products:
Eheim compact Pum...
from 19,95 EUR
incl. 19 % Tax excl.
1 x 'Eheim compact Pump 1000/230V' order
GELID Low Noise f...
from 4,99 EUR
1 x 'GELID Low Noise fan-1000 RPM 20.2 dBA (120x120x25mm)' order
Barb Fitting exte...
from 1,85 EUR
1 x 'Barb Fitting external thread G1/4" on 8mm - black nickel plated' order
Screw connector e...
from 0,59 EUR
1 x 'Screw connector external thread 1/4" on 8/6mm' order
Tubing PUR 8/6mm ...
from 0,35 EUR
1 x 'Tubing PUR 8/6mm transparent' order
Alphacool AGB-Ehe...
from 35,95 EUR
1 x 'Alphacool AGB-Eheim 600 Station II 230V' order
  • Welcome back !
  • eMail Address
  • Password
  • Newsletter Subscribing!
  • eMail Address
