- Categories
- Informations
- Sitemap
- Last viewed:
- Alphacool NexXxoS Pro I - Rev. 2
- from 22,95 EUR
incl. 19 % Tax excl.
Alphacool NexXxoS XP light Plexi Socket 775
- Product No.:11711
- Shipping time: 3-4 Days
- Print product data sheet:
- Item may vary slightly from product image.
- Lieferstatus:
The NexXxos XP Light is a new kind of plexi and copper cooler with parallel channels in a PCF(c) construction.
Additionally, the channels are drilled in 90° angles - thus the surface area is enourmously increased for heat transfer.
The copper surface is glass-beaded in order to increase the cooling surface once again.
The cooler has a patent-applied nozzle unit with return canals for quicker transport of warm water.
The flow resistance is reduced by 30%, which is a very good condition for systems with G1/4" connections and 10/8mm tubing.
The NexXxoS XP Light was designed with a plexi top cover to reduce weight and therfore strain on the motherboard.
Further mechanical advantages arise due to the central pressure force of the middle screw and easy mounting
since you don't have to remove the motherboard.
The surface of the cooler is even and polished.
Technical Data:
Total Dimensions (without connections): 50 x 50 x 17 mm
Weight: approx. 0,100 kg
Structure: Copper base and Plexi top / Degussa ®
Fasteners: Intel Socket 775 Fastening Bracket with Center Pressure Screw
Customers who bought this product bought also the following products:
- More about...
- Shipping & Returns
- Privacy Notice
- Conditions of Use
- Imprint
- Contact
- Where 2 Buy
- Forum
- New Products
- Alphacool HF 14 Smart Motion Universal W / R
- from 34,95 EUR
