Languages
Alphacool NexXxoS X2 Bold HIGHFLOW Socket 775
  • Product No.:11714
  • Shipping time: 3-4 Days
  • Print product data sheet:
  • Item may vary slightly from product image.
  • Lieferstatus: Lager voll
from 49,95 EUR
incl. 19 % Tax
excl.
Alphacool NexXxoS HIGHFLOW Serie Quad Core Ready
With this cooler 53 nozzles enable an extremely balanced dispersal of coolant to the heated area and with the help of 8 backflow channels to quickly take the heated coolant away to the radiator.
The 8 backflow channels are optimized PFC(c) over the pin structured baseplate so as to enable the fastest possible waterflow through the cooler.
Our Highflow models give you the possibility of an extremly high flowrate of coolant, thus dispersing the heated coolant much more quickly and efficiantly and also leaving less stress on the pump.
Technical Data:
Flow rate: 4,7 L/m
Nozzles: 53
Backflow Channels: 8
Weight: approx. 0,300 kg
Structure: Cooper / Plexiglas Röhm / Degussa ®
Customers who bought this product bought also the following products:
Tubing 11/8 PVC g...
from 2,95 EUR
incl. 19 % Tax excl.
1 x 'Tubing 11/8 PVC green UV-active' order
Cooling fluid Nan...
from 8,90 EUR
1 x 'Cooling fluid Nanoxia Iceglow Fluid 1000ml UV-active aqua blue' order
Alphacool AGB-Ehe...
from 74,95 EUR
1 x 'Alphacool AGB-Eheim 1000 Station Rev. II - 12V' order
Screw connector e...
from 2,39 EUR
1 x 'Screw connector external thread G1/4" for 11/8 rotatable' order
Decoupling set fo...
from 3,99 EUR
1 x 'Decoupling set for Eheim/Hydor/Laing Attachment (1x internal thread / 1x external thread) 4 pieces' order
Alphacool NexXxoS...
from 31,95 EUR
1 x 'Alphacool NexXxoS Pro II - Rev. 2' order
  • Welcome back !
  • eMail Address
  • Password
  • Newsletter Subscribing!
  • eMail Address
  • New Products
  • Alphacool Pumpenadapter
  • from 3,59 EUR
