Laing DDC-Pump 12V Ultra
- Product No.:13912
- Shipping time: 3-4 Days
- Print product data sheet:
- Item may vary slightly from product image.
- Lieferstatus:
This pump is the first one in the world which is being brought into action in serial produced watercooled workstations and is ideal for the watercooling of processors and electronical components.
Furthermore it has multiple applications due, due to its size and performance.
This DC pump is an electronical commuted ball engine pump with running periods of notedly more than 50.000 hours at 12 volt. The only moving part of a ball engine pump is a spherical formed rotor-/ running wheel unit which bases itself on an ultra hard wear-resistant ceramic bearing ball.
A conventional shaft with shaft bearings and shaft seals does not exist. The spherical bedding of the rotor-/ running wheel unit on the ceramic bearing ball offers many advantages: neither bearing clearance nor increase of noise is possible - due to this principle. So the pump stays at a low noise level during the whole running period. The bearing is self-adjusting and is lubricated directly from the pumping medium (wet running pump). This makes maintenance unnecessary!
As the rotor always is magnetically held in the provided position, tiny soil particles are no problem.
Normally a blockage of the pump is not possible. Also after longer standstill the pump starts confidently. The permanently magnetical rotor-/ running wheel unit is being moved by a magnetic force which is produced by the stator around. This stator is completely mounted around the rotor.
This, the pump with its 38 mm is just a little higher than the stator itself and fits into all standard PC-, barebone- and mini-PC cases without any problem. Usually, a separate magnetical shielding is not necessary. The ball enginge principle offers an economical use with comparatively high performances. Due to voltage variation, the DCC direct current pump can be regulated very simply and at large performance range. All media contacting parts are completely corrosion resistant.
Technical Data:
Dimensions: (WxLxH) 80x80x45mm (without connections)
Motor construction type: electronically commuted ball-motor
Working voltage: 12 V DC Voltage 18w
Admissible voltage area: 6 to 13,2 V
Delivery height: at 12V: 4.7m
Max. Delivery rate: 600L/h
Delivery media: water, water-/glycol compounds
Max. System temperature: 60°C
Medium-affecting parts: stainless steel 1.4571, PPS-GF40, EPDM O-sealing rings,hard carbon
Connections: 2x G1/4" hose connections
Customers who bought this product bought also the following products:
- More about...
- Shipping & Returns
- Privacy Notice
- Conditions of Use
- Imprint
- Contact
- Where 2 Buy
- New Products
- Warrior Gaming-Keyboard, blue, Version 2
- 34,90 EUR
incl. 19 % Tax excl.
