- Categories
- Informations
- Sitemap
Laing DDC-Pump 12V Ultra AGB - 18Watt
- Product No.:13913
- Shipping time: 3-4 Days
- Print product data sheet:
- Item may vary slightly from product image.
- Lieferstatus:
This pump is the first one in the world which is being brought into action in serial produced watercooled workstations and is ideal for the watercooling of processors and electronical components.
Furthermore it has multiple applications due, due to its size and performance.
This DC pump is an electronical commuted ball engine pump with running periods of notedly more than 50.000 hours at 12 volt. The only moving part of a ball engine pump is a spherical formed rotor-/ running wheel unit which bases itself on an ultra hard wear-resistant ceramic bearing ball. A conventional shaft with shaft bearings and shaft seals does not exist.
The spherical bedding of the rotor-/ running wheel unit on the ceramic bearing ball offers many advantages:
neither bearing clearance nor increase of noise is possible - due to this principle. So the pump stays at a low noise level during the whole running period. The bearing is self-adjusting and is lubricated directly from the pumping medium (wet running pump). This makes maintenance unnecessary!
As the rotor always is magnetically held in the provided position, tiny soil particles are no problem. Normally a blockage of the pump is not possible. Also after longer standstill the pump starts confidently.
The permanently magnetical rotor-/ running wheel unit is being moved by a magnetic force which is produced by the stator around. This stator is completely mounted around the rotor.
Thus, the pump with its 38 mm is just a little higher than the stator itself and fits into all standard PC-, barebone- and mini-PC cases without any problem. Usually, a separate magnetical shielding is not necessary. The ball enginge principle offers an economical use with comparatively high performances. Due to voltage variation, the DCC direct current pump can be regulated
very simply and at large performance range. All media contacting parts are completely corrosion resistant.
The optimal water tank for the Laing DDC pump
This water tank is thus designed, that it can be mounted and decoupled in any imaginable form. By means of the decoupling sets (enclosed), the Laing can be mounted completely decoupled in 3,5”-shafts, for example at the bottom side, by means of the standard decouplings or even better in place of 80mm fans. Any position is possible for the attachment as well, you may fulfil your projects by using your fantasy.
The water tank disposes of 5mm LED drillings for Case Modders and it has a capacity of 110ml.
Technical Data:
Dimensions: (WxLxH) 80x80x97mm (without connections)
Motor construction type: electronically commuted ball-motor
Working voltage: 12 V DC Voltage 18w
Admissible voltage area: 6 to 13,2 V
Delivery height: at 12V: 4,7m
Max. Delivery rate: 600L
Delivery media: water, water-/glycol compounds
Max. System temperature: 60°C
Medium-affecting parts: stainless steel 1.4571, PPS-GF40, EPDM O-sealing rings, hard carbon
Connections: 2x G1/4" hose connection
Customers who bought this product bought also the following products:
- More about...
- Shipping & Returns
- Privacy Notice
- Conditions of Use
- Imprint
- Contact
- Where 2 Buy
- Forum
- New Products
- Noise Destructor v1.1 Pumpenentkopplung
- from 4,99 EUR
incl. 19 % Tax excl.
