Languages
NexXxoS Pro I - Rev. 2
  • Product No.:14124
  • Shipping time: 3-4 Days
  • Print product data sheet:
  • Item may vary slightly from product image.
  • Lieferstatus: Bestand knapp
27,90 EUR
incl. 19 % Tax
excl.
The NexXxoS Pro l, Rev 2 delivers not only performance, but is also an eyecatcher due to the perfect engineering.
Its design, with the parallel channels gives the least amount of resistance of waterflow.
The NexXxoS Pro Radiators are among the best in their class for heat exchangers, they have the posssibility to fix fans on both sides, and are able to be fitted in almost all cases.
Technical Data:
Dimensions L x B x H: 157 x 132 x 30 mm
Weight: approx. 0,450 kg
Connections: 2x G1/4" inch
Distinctive Features: Pressure tested up to 8 bar
Customers who bought this product bought also the following products:
8,90 EUR
incl. 19 % Tax excl.
1 x '' order
NexXxoS Xtreme I ...
33,90 EUR
1 x 'NexXxoS Xtreme I - Rev. 2' order
Thermosensor In-L...
19,90 EUR
1 x 'Thermosensor In-Line 10/8mm mit Display' order
Tubing PVC 11/8mm...
2,95 EUR
1 x 'Tubing PVC 11/8mm UV-active blue/blue' order
Screw angle AG 1/...
3,25 EUR
1 x 'Screw angle AG 1/4" on 11/8mm' order
Screw connector s...
0,89 EUR
1 x 'Screw connector swivel nut 11mm' order
  • Welcome back !
  • eMail Address
  • Password
  • Newsletter Subscribing!
  • eMail Address
