NexXxoS Pro II - Rev. 2
- Product No.:14125
- Shipping time: 3-4 Days
- Print product data sheet:
- Item may vary slightly from product image.
- Lieferstatus:
The NexXxoS Pro lI, Rev 2 delivers not only performance, but is also an eyecatcher due to the perfect engineering.
Its design, with the parallel channels gives the least amount of resistance of waterflow.
The NexXxoS Pro Radiators are among the best in their class for heat exchangers, they have the posssibility to fix fans on both sides, and are able to be fitted in almost all cases.
Technical Data:
Dimensions L x B x H: 278 x 132 x 30 mm
Weight: approx. 0,630 kg
Connections: 2x G1/4" inch
Distinctive Features: Pressure tested up to 8 bar
