Languages
Spacers for NexXxoS Pro/Xtreme Radiators
  • Product No.:14539
  • Shipping time: 3-4 Days
  • Print product data sheet:
  • Item may vary slightly from product image.
  • Lieferstatus: Lager voll
6,90 EUR
incl. 19 % Tax
excl.
Plexi spacers for all NexXxoS Pro Rev. 2 and NexXxoS Xtreme Rev. 2 Radiators.
These spacers enable the fitting of the radiator on the top of the case, without having to drill or cut. All you need do is drill 4x holes 3,2mm for the M3 Screws.
The Plexi spacers give you a Top Optic and a distance of approx. 34mm between Radiator and the top of the case. This enables a perfect airflow through the Radiator.
Included in delivery:
4 x M3 x 40mm Screws
4 x approx. 34mm Plexi Spacers
8 x Washers
Customers who bought this product bought also the following products:
AGB-Eheim 1000 St...
99,00 EUR
incl. 19 % Tax excl.
1 x 'AGB-Eheim 1000 Station Rev. II - 12V' order
Alphacool NexXxoS...
50,00 EUR
1 x 'Alphacool NexXxoS X2 "5th Anniversary" UV-active' order
Screw angle AG 1/...
3,95 EUR
1 x 'Screw angle AG 1/4" on 10/8mm with antikink spring' order
Screw passageway ...
3,25 EUR
1 x 'Screw passageway connector 10/8mm' order
Bolt & spring AG ...
2,85 EUR
1 x 'Bolt & spring AG 1/4" on 10/8mm' order
NexXxoS NVXP-G92 ...
89,95 EUR
1 x 'NexXxoS NVXP-G92 NVidia' order
  • Welcome back !
  • eMail Address
  • Password
  • Newsletter Subscribing!
  • eMail Address
